1969 Camaro ss 396 highway headlights
What are the correct wheels for this car. Factory wheels. 2nd question 1969 Camaro DZ 302 muncie transmission. Need new clutch factory original needs replacing. Light street and some track type takeoffs. Any suggestions thanks to all
Pretty sure the '69 Z28's had the 15" rally wheels and as for the clutch if the rest is stock an OEM stock clutch should be fine,you can spend a lot more if you want of course but that would probably be overkill.
https://www.automobile-catalog.com/t...ort_coupe.html https://cimg7.ibsrv.net/gimg/camarof...5c8a387017.jpg |
I like the center force dual friction clutch. Sitting in the car if feels stock but has 80-90% more holding power and will out last a stock clutch treated the same way. It is by no means a race clutch just upgraded stock clutch.
Depends on when your car was built. These are the SS wheels up to a January build date, then they were discontinued.
https://cimg4.ibsrv.net/gimg/camarof...b4ac82b3bf.jpg |
(Post 731823)
Only 314 of them to be exact, so yeah pretty rare.
