needing a better clutch
Old Jul 20, 2012 | 05:33 PM
tespjs12's Avatar
Default needing a better clutch
I need some help, I put a 350 in my 1992 rs camaro ,when i put it together i put a new stock clutch in it. Well now its been 4 months and it is starting to get week, can anyone give me advise on a good clutch that will last longer. I cant afford much . thanks for any help.
Old Jul 20, 2012 | 10:43 PM
How much power is your engine producing? Clutch life is influenced by driving habits more than engine power. Keep in mind that the stronger the clutch, the stronger your left leg needs to be, and this can get old fast if you are driving in stop & go traffic.
Old Aug 15, 2012 | 06:21 PM
tespjs12's Avatar
385 hp to the flywheel i do more cruising than any but dont want it to slip when i want to get on it
Old Aug 15, 2012 | 07:47 PM
Edwardgp's Avatar
You can step up to an aftermarket pressure plate and still use the stock clutch.
Old Dec 17, 2012 | 02:11 PM
tespjs12's Avatar
when sitten at stop light with clutch in the car barely moves will a aftermarked pressure plate help that and it slip when i punch it.
draven666
Dec 7, 2014 11:17 AM
!WildChild!
Oct 17, 2011 08:22 PM
Bryan09
70-81 V8 Tech
Nov 23, 2009 12:37 PM
mario82z28
Jun 9, 2009 10:12 AM
