1969 camaro dome light
I will be putting in a new headliner. Before I do I want to install a new clean dome light. I know that I need to get the done light wiring kit. Where do the two wires go that go away from the dome light. I also need to get the door pressure buttons to turn on the dome light when the doors are open. Also do I need one terminal or two terminal buttons. Where does the power source come from, or located at. Want to get this done before the headliner is put in. Thanks, Jerod
The dome wires run along the roof to the drivers side and run down the B pillar and plug into the harness going to you rear light harness. There are two, one orange and one white wire. Both doors have only a one terminal switch.
