1967 Fuel Issue
Old Feb 25, 2023 | 02:12 PM
roscoe's Avatar
Default 1967 Fuel Issue
My '67 big block Camaro is driven occasionally, parts runs, car shows and cruise-ins. I was driving away from getting parts the other day and kinda got on it hard. Response was great but when I let off the throttle, the engine rpms dropped slowly and it died. Started back up after pumping the throttle about a half dozen times. It has a Holley based carburetor, blue pump with a new filter before pump and before carb. Pump is mounted below the bottom of the tank and I set pressure at the regulator to about 7 psi. I'm thinking that the tank vent may be plugged or there is some kind of restriction in the supply line to the pump. Anyone have a similar issue? I am attaching a pic of the vent valve that is supposed to be located inside a frame rail. I've never seen it on my Camaro. It was probably taken off years ago before I purchased it. I'm gonna pull my tank down and check everything out.
Old Feb 25, 2023 | 04:54 PM
Sure sounds like a vapor lock of some kind.
How old are the rubber lines?
Old Feb 26, 2023 | 12:21 PM
roscoe's Avatar
All rubber lines are new from each end of the tubing. In fact, everything is new from the tank to the carb. I'm gonna pull the tank soon and I'll share what I find.
Old Mar 8, 2023 | 08:20 AM
manicmechanic007's Avatar
Alky in the fuel, sure does suck for carbureted vehicles
If you have vapor lock with an electric pump
Remove one of the fuel filters, first (the one before the pump)
A California emissions fuel lines setup, with a return would help
You could up the pressure and install an additional regulator just before the carb
The Cal emissions fuel return line, could take some of the reserve pressure back to the tank
Old Mar 26, 2023 | 05:52 AM
xomlak's Avatar
hello, i want a push button start like yours. where I can buy. I am French. Thank you
192.168.100.1 192.168.1.1
roscoe
67-69 V8 Tech
Jun 9, 2022 05:26 AM
vipe155
Aug 26, 2019 10:23 AM
brownstone101
Apr 6, 2011 08:54 AM
ohbhave
Feb 18, 2010 06:13 PM
adirtypoostick
82-92 V8 Tech
Feb 6, 2009 06:30 AM
