1967 Camaro Brake pull
Old Aug 9, 2023 | 08:24 AM
Mick's Avatar
Default 1967 Camaro Brake pull
Hey guys. This is what I got. Customer brought in a 67 Camaro with a disk brake conversion kit including new master booster lines caliper’s spindles the whole kit. Apparently all was good till he pulled it out of storage this year. It now has a hard pull to the right. But soon as u let off the pedal it straightens out. I put a new line and caliper on the left front bled all the brakes adjusteded the rears and still no difference. Checked all the suspension too. The steering wheel will actually turn to the right , it does it in reverse as well. I’m stuck. Any ideas?
Old Aug 9, 2023 | 02:55 PM
You ever use a brake pressure gauge? I also would have assumed brake line or suspension part. After that I would go to the gage and see if the pressure is the same right to left. If the pressures are the same you can swap the pads or even the rotor. If it still pulls I would look for a bad suspension that only flexes under extreme pressure or even subframe issues. If the pressures not the same you need to work backwards up the line to see if there is a restriction. All the way back to the Master.
Old Aug 11, 2023 | 11:48 AM
SoCal67's Avatar
OP, good points in post 2
I would also look into a pinched hard brake line along frame (where it crosses rear sub-frame) and on rear end (U bolt over brake line)
usered
Jun 29, 2022 06:40 PM
9434V6
May 19, 2013 04:35 PM
250motorsportz
May 8, 2008 12:51 PM
trevscamaro
Mar 25, 2007 02:47 AM
Goodfella
Nov 20, 2006 11:38 PM
