a/c, defrost, heat selector sw ng?
Old 08-21-2011, 01:29 PM
capt.rick's Avatar
Default a/c, defrost, heat selector sw Fixed
Hi guys, new to the forum and new owner of a 97 camaro, 6cyl, have been searching for this problem for a while with no luck. maybe searching wrong. Anyway there is no difference where i put the switch, blows out at defrost , have been searching for a vac leak with no luck but while chasing hoses I found this connector and took it apart and there is no vac at all. Is there supposed to be and if so where do i look next, thanks, capt
Old 08-22-2011, 05:03 PM
capt.rick's Avatar
Changed this two way check valve that was cracked and clogged and it did the trick. I was not getting any vacuum at the fitting behind the glove box so I traced it back to here v, (a $4.00 part @ carquest)
Old 08-23-2011, 01:24 PM
thanks for letting us know what it was. i was trying to figure out what hose you were talking about and lost track of the thread.
Old 08-23-2011, 02:47 PM
Grandpaswagon's Avatar
It is nice when folks update their threads with their findings. That last post could potentially solve the same problem for another member.
Old 08-24-2011, 05:48 PM
capt.rick's Avatar
I belong to a few different forums, and I look for answers just like everyone else, and if nobody posted up there findings , it would be just another chat room.
Old 03-31-2012, 05:27 PM
DOLCI96's Avatar
Default Thank U! Thank U! Thank U!
I finally got my dream car a 1994 Z28 convertible...now the fun begins w fixing all the little things that pop up for an older car. Im not mechanic by any stretch but i can follow directions. When my AC went out, I followed the clues to figure out what the problem was and ur post was the PERFECT answer to fix it!! Took me 10 minutes!!! Girl Power! lol Now I gotta figure out how to change the oil pan gasket!!! Thanx for the help and pictures!!
Capt Shark
04-10-2014 08:21 PM
microkid
02-01-2010 07:03 PM
1974z28
10-10-2009 01:51 PM
94CamaroSFI
10-13-2006 07:48 PM
SickSickSick
05-21-2006 05:58 PM
Quick Reply: a/c, defrost, heat selector sw ng?
