Convertible top will not go down
Old Jun 1, 2017 | 07:27 PM
audiotek's Avatar
Default Convertible top will not go down
i have a 2017 ss convertible. it was seized vehicle. i purchased without amplifier, vent shade and other miscellaneous items. Can someone please help me with the convertible top? when i push the button near rear view mirror it says to secure vent shade. i dont have the vent shade and read i could just disconnect sensor to bypass. i had also tried jumping the sensor to close the loop. now the message says only manual operation is possible. i dont hear any motors or anything when i press the top up/down switch. the amplifier was missing from vehicle and i replaced with an aftermarket unit. could that have anything to do with it? Does anybody know what the problem could be?
Old Jun 2, 2017 | 06:12 AM
Everett#2390's Avatar
Is there a foldable shelf the top folds into?
A lot of 'Verts, open the trunk, and if one needs more room, top shelf the top folds into, can be folded up using the supplied lever.
Unfold the shelf and top goes down.
Might be worth the time & money for an Owner's Manual.
Old Jun 2, 2017 | 09:21 AM
peterpar's Avatar
Everett's right, try checking the owners manual for operating instructions. Here's a link for a pdf copy.
Old Jun 2, 2017 | 11:19 AM
peterpar's Avatar
After reading some of the owners manual, I found that a partition between trunk and top storage area has to be in place before the top will operate. Have you checked to verify this is installed correctly? Also, you mention getting a message to secure vent shade. I can't find any error messages for a convertible top problem like that. The closest reference in the manual to a vent shade that I could find would be the sunshade of a vent/sunroof.
Old Jun 2, 2017 | 01:30 PM
audiotek's Avatar
Default Correction to display message
correction to extend vent shade. it says "extend cargo shade to operate top." then when i jump/bypass sensor where the cargo shade snaps on to the message displays "top can only be operated manually." this cargo shade is what i believe to be a partition. i did read the owners manual and it just take to dealer. i attched some pictures of the cargo shade sensor that the shade snaps on to and a picture of the section that opens and the top folds into. the trunk does not open for that stage of top opening.
Attached Thumbnails Convertible top will not go down-20170602_112432.jpg   Convertible top will not go down-20170602_112437.jpg   Convertible top will not go down-20170602_112454.jpg   Convertible top will not go down-20170602_112508.jpg
Old Jun 12, 2017 | 03:48 PM
wldcatr's Avatar
Smile Soft Top Works.... and special Sale
cargo shade is what i believe to be a partition is the issue and once 'buttoned' the top works.
btw... am selling my 2016 2SS convert/ blk /blk all options, 3700miles because my Macan comes in next week... this cam is perfect and the price is a killer.... low 40's!!! so if you're lookin.. look no further!!
Old May 9, 2023 | 11:38 PM
originalryan's Avatar
Yea just do this, it'll fix it pretty quickly but it's not something you'd probably come up with on your own. I'm surprised the error isn't in the users manual.....
https://sharpmind.samcart.com/produc...sible-easy-fix
Old Jun 11, 2023 | 02:10 PM
blewis01@ymail.com's Avatar
Hi my name is Ben im looking for a shop that with do a t top on my 2023 2SSLE.can you help me?
DashingDaryl
Feb 20, 2012 03:55 PM
LT1RUNNER
Nov 12, 2008 01:01 AM
miguelg510
Jun 11, 2008 08:46 PM
miguelg510
82-92 V8 Tech
May 27, 2008 01:57 AM
