Supercharger
I just don't understand why you guys want to S/C a small v-6 in a car that was desgined to handle a v-8. A charger runs like 3 to 5k once you add in supporting mods right? For the same money you can pick up a tired 350, have it re-worked, and upgrade your trans. You'll end up with more hp and proally save a lil cash.
i found a used supercharger that can be retrofitted for a 2.8 from a private seller for 300 and the chip i was looking at is only 160 so i figure for around 500-550 i could do this and still keep my crankshaft intacted for the time being until i can get a bigger engine. because if i get a bigger engine i want something in the 4's like a 454 but then i would have to get a transmission to handle it and possible a heavier duty rear end so i think the first option is cheapest right now
was the edelbrock a complete kit with everything you need, what are the hp/tq numbers supposed to be after the install? are you a a6 or m6?
