2010+ V6 Tech discuss modifications to the all new 3.6L v6 here.
350 engine swap?
Old Jun 23, 2009 | 04:40 PM
donovanwilliams's Avatar
Default 350 engine swap?
I was wondering if i can swap out my 1995 3.4 V6 engine 4th generation, with a 350 4 bolt main out of a Z71 and still keep my five speed transmission? i was told that i would have to get a whole new transmission, and i was also told that i could use the 5 speed transmission that is in it, just change the belhousing, which would cost about $100? does anyone have any suggestions, or if i can actually do this engine swap and still use my tranmission?
Old Jun 23, 2009 | 06:34 PM
kma5783's Avatar
Z71? Out of what truck, a silverado?
And what year?
What Transmission is in the camaro, a T-5?
Old Jun 23, 2009 | 06:38 PM
kma5783's Avatar
By any chance do you mean Z28?
Old Jun 24, 2009 | 05:08 PM
no its a Z71 truck, i believe a Silverado 1500, and I'm not to sure what the transmission is, its the stock one that's in that 1995 V6 5 speed camaro. Everything is stock on the car, i just wanted to know if i could use that transmission, if i can i would change out the motor. i want more power, thats all. unless there would be an easyier cheaper way?
Old Jun 25, 2009 | 05:49 PM
kma5783's Avatar
I'm pretty sure it can be done, I can't give you definite answer without the year of the truck. Need to be able to determine what 350 it is, LS1, LT1, Old Small Block
The stock transmission in your car is a t-5 which isn't really built to handle that power you'll eventually destroy the transmission, you can either upgrade the transmission to handle the power or you can buy a used t-56, which is a 6 speed and you'll be good to go.
Old Jun 25, 2009 | 10:28 PM
u will need to change the wiring, the ecm, the k member, the suspension, the trany, the driveline and a few things i probly missed. buy a z if thats what u want.
Old Jun 27, 2009 | 01:55 PM
do you know how much the six speed transmission would cost? or where i could find one? its hard to find used motors and transmissions for these things?
Old Jul 1, 2009 | 06:30 PM
cbr600rx7's Avatar
A T56 swap will run around 3 grand by the time you are done with it. If you are going to do a SBC swap keep it carbed that way you dont have to deal with the ECU and Fuel Injected wiring harness. This is not a easy swap as you are going to need parts from a LT1 car and from the carbed vehical you get the engine out of. Keep in mind this would be a very large project and its going to cost you A LOT. By the time you are done you could have picked up a clean LT1 car or maybe even a LS1 car with a few miles.
3800_seriesII
Aug 14, 2012 07:24 AM
jrb78
82-92 V8 Tech
11
Dec 16, 2007 07:05 PM
cachaco736
Dec 11, 2007 11:12 AM
uradumass5695
Oct 21, 2006 08:27 AM
illumastar
Oct 20, 2006 01:42 PM
