LED tail light 2015 RS LT1
Old Nov 15, 2020 | 03:16 PM
dorin12's Avatar
Default LED tail light 2015 RS LT1
So my left LED tail light is not working anymore I went to three diferent mechanics and they all told me i need to change it. and is pretty expensive 400$ just for one light and the only cheap option is buying a halogen so my question is if i change from LED to halogen do i need a harness conector or something becuase i don't know if it should be included if i order
Old Nov 15, 2020 | 07:18 PM
The original bulb should be a 7444, but you can also use a 7443. An incandescent bulb is only a few bucks, you can get an LED version for $10 - $30, depending on where you shop. For $400, are they replacing the entire tail light assembly? Even at that, you'd still be getting ripped off.
Old Nov 16, 2020 | 02:45 AM
dorin12's Avatar
yeah i was talking about replacing the entire assembly because it does not have bulbs
Old Nov 16, 2020 | 11:40 AM
HenryC's Avatar
Do you care about oe? There's some cheaper after market tail light assemblies that will look good. I'm assuming no because you mentioned halos, I think you will need a harness adapter but it should come with the lights.
Old Nov 16, 2020 | 05:03 PM
dorin12's Avatar
Nah man oe rn for me is to expensive and yea i'm going with halos but like i said i was not sure if i needed a harness adapter but it should come with the lights like you said, I'll ask the seller first and see. Thx for response
Old Nov 17, 2020 | 08:51 AM
Drew Peacock's Avatar
you have the euro tail lights i bet
Old Nov 17, 2020 | 10:10 AM
dorin12's Avatar
they are like these ones
mthorn
LS Series Tech
Jul 2, 2008 09:19 PM
buckmaster
Aug 4, 2007 06:27 AM
350rs
Jul 18, 2006 12:42 AM
exciter88
Mar 17, 2006 02:36 PM
