2011 Steering Issue
Old Feb 17, 2022 | 02:27 PM
Combatvet's Avatar
Default 2011 Steering Issue - Fixed
I have a 2011 2LT. It's been sitting for 2 weeks due to ice, took it for a drive and I have a shaking in the steering both while driving and while parked. Checked the PS fluid, added some to bring it up to proper level, bled the system. I can turn the wheel just fine, but what gets me is while parked the steering wheel will shake, almost like the wheel bearings are bad.
Any ideas? I am thinking about flushing the PS system at the return line to see if that helps.
Old Feb 18, 2022 | 08:10 AM
Cheeks's Avatar
August 2011 ROTM
what is the tire pressure set at? Could it be low(ish) and dragging the tire through the arc?
Old Feb 19, 2022 | 08:37 PM
Combatvet's Avatar
Think I figured it out. Ended up flushing and refilling the power steering fluid using a method on YouTube that worked really well. 3/8" ID clear vinyl tubing is a must. No issue since finishing.
sgreg831
Nov 15, 2012 05:41 AM
jkeaton
Sep 3, 2012 06:01 PM
vashtx
LS Series Tech
12
Aug 27, 2009 05:07 PM
stealthy95z
Nov 19, 2008 06:40 PM
