Lowering Question?
Old Jan 15, 2007 | 02:57 PM
RyanBumZ28's Avatar
Default Lowering Question?
Hey Guys, I have a 1995 Camaro Z28. I would like to lower it just a little bit, so here's the question. Do I have to buy lowering springs, or is there a way that you can lower the stock suspension. I know that the suspesion on my dad's corvette is adjustable, so I was wondering if my Z28 was the same way. Thks in advance for the help.
Old Jan 15, 2007 | 04:06 PM
Default RE: Lowering Question?
No adjustments, you will need to change springs, and then drag the ground going over driveway aprons.
Old Jan 15, 2007 | 09:14 PM
shnormo's Avatar
You might have to adjust camber and your suspension.
Old Jan 17, 2007 | 10:00 PM
badinfluenceRS's Avatar
eibach pro kit will lower 1+"
no shocks are needed but recommend
Old Jan 20, 2007 | 03:48 AM
v8chvyguy's Avatar
ORIGINAL: shnormo
Anytime you modify the suspension you need to alighn it afterwards.
CaCruiser
Oct 30, 2014 05:18 PM
IndianScout
Aug 15, 2013 09:26 AM
matacaleb20
Mar 25, 2012 09:51 AM
BHoskins24
Apr 14, 2011 09:45 PM
maxxiepad
Feb 7, 2007 02:28 PM
