Lowering Question?
Hey Guys, I have a 1995 Camaro Z28. I would like to lower it just a little bit, so here's the question. Do I have to buy lowering springs, or is there a way that you can lower the stock suspension. I know that the suspesion on my dad's corvette is adjustable, so I was wondering if my Z28 was the same way. Thks in advance for the help.
RE: Lowering Question?
No adjustments, you will need to change springs, and then drag the ground going over driveway aprons.
You might have to adjust camber and your suspension.
eibach pro kit will lower 1+"
no shocks are needed but recommend |
ORIGINAL: shnormo You might have to adjust camber and your suspension. |
