Clicking noise
Old Dec 26, 2006 | 05:43 PM
Hiwaystar's Avatar
Default Clicking noise
I have a '97 V6 with 73k miles. Have a clicking noise at very low speed and a steering wheel shimmy at speeds above 50 or so. Lifting the front end reveals nothing- tie rod ends are relatively new( takes care of wheel shimmy)and no clicking noise whenI spin tires.
Lifting the rear end and running vehicle reveals nothing either.
I suspect wheel bearings( clicking noiseresult of vehicle weight on hub assembly), although not sure which side. I realize hub assembly is not serviceable, but before I dig deeper was hoping someone has had similar experience. Thanks for any replies.
Old Dec 26, 2006 | 06:36 PM
Default RE: Clicking noise
Check wheel alignment and balance if you are getting wheel shimmy. New tie rods themselves will not correct the problem.
Old Dec 30, 2006 | 02:04 PM
v8chvyguy's Avatar
This may sound simple, but, a nail in a tire will make that sound, also, ujoints
BoricuaHec01
Aug 13, 2008 12:45 AM
evilkal
Mar 31, 2008 03:56 PM
eitan
Nov 10, 2007 02:08 AM
V6Cam2000
Oct 6, 2007 11:24 PM
V6Cam2000
Jul 13, 2007 12:03 AM
