305 TPI Engine
Old Jul 30, 2006 | 11:22 PM
Corr182's Avatar
Default 305 TPI Engine
Hello everyone, I have a 1991 Z28 with a 305 Tuned Port Engine. I just got a rebuilt motor from Jasper, $1800, it has about 280 miles on it since it was dropped in.
I was wondering, it doesnt have the same get up and go, I am tryin to baby it for a while and "break it in", but I was wondering if after the 500 miles
and I change the oil if it will be any faster? They also left in the 350 ECU, I have the 305 ECU still, but these are just some things I was wondering...
All jasper engines are supposted to be O.E.M. specs, so she should be like it was before..... .thanks for your input.
Corey
Old Jul 31, 2006 | 12:02 AM
Default RE: 305 TPI Engine
If you are using a 350 ECU on a 305 engine, and it hasn't been tuned for a 305, then you are probably having fuel A/F misture problem and the engine is not running at it's full potential. You may want to put in the 305 ECU. I don't quite understand why Jasper would send you a 305 engine with a 350 ECU, or am I not reading your post properly?
Old Jul 31, 2006 | 01:53 AM
Corr182's Avatar
thanks pete... I had a 305 TPI and it blew, bought a 350 TPI off some kid... blew... so when they swapped the 350 in, I got the ecu and everything for it... like Its really hard to spin the tires and it isnt as powerful, I take it I should put back in that 305 ECU? .... thanks for the help! -- Ok I know this may sound dumb, but there is 2 wires 2 main blue ones that go into my 305 ECU and when I unplugged the 350 one, unless I got the wrong thing, it had the 2 main blue wires that fit into it, but it the 350 ecu also has a a main power wire that the 305 doesnt any help of where the power wire goes to??
P.S. the 305 ecu numbers is this... 1227165
350 says this.... Delco Electronics 16198262-- I think this may be my ECM thou... help please?
Old Jul 31, 2006 | 03:19 PM
blackz87's Avatar
The computer for a 305/350 are the same. The only difference is in the Prom ( aka chip). If you running a 305 TPI that is the chip you will need, otherwise the inputs from 350 chip will cause problems.
Old Jul 31, 2006 | 03:23 PM
Corr182's Avatar
how do I do that? sorry
Old Jul 31, 2006 | 03:39 PM
blackz87's Avatar
ORIGINAL: Corr182
You will need a 305 TPI chip and remove the present chip from the ECM (computer). it is has a pin type plug and is the only one that can be removed. Use the new chip as a ref because they are the same in appearance.
Old Nov 9, 2009 | 04:04 PM
vinny91's Avatar
Default 305 tpi having studering off and on
i have a 305 tpi i put a new clutch in it and before it ran great ...but then after i put the clutch in it ran like crap and i changed the knock sensor that didnt fix the problem..the car ran the code for knock sensor and i cant find the plug to unplug so i can time it right and i had a buddy fix my timing it ran better but not great i could always spin the tires over before the new clutch and its very doggy it has no get up and go cant roast them ...i also had a problem only once of my left exhaust manifold heated up to bright see though read but my car was not over heating...thank you for the help
onefastls1
Jan 2, 2013 01:45 PM
martynlutherking
May 25, 2010 11:12 PM
Chevykicksbut
Oct 28, 2009 07:14 AM
drabina
Jul 25, 2008 08:56 PM
jrb78
11
Dec 16, 2007 07:05 PM
