cold start injector temp sensor?
Old Aug 29, 2010 | 08:01 PM
microkid's Avatar
March 2011 ROTM
Default cold start injector temp sensor?
well i know i dont have mine because i took it out and replaced it with the sending unit for my temp gauge. now i cant find one that is definatly what i need. now i have found two at advance auto, but im not sure if they are what i need. i do have a few connectors that were un-labeled from my tear down almost 3 years ago, theres 5 all total. i was going to cross reference them in my wiring diagram to find out what exactly they were for.
http://shop.advanceautoparts.com/web..._1100259317___
http://shop.advanceautoparts.com/web..._1100268710___
Old Aug 29, 2010 | 11:46 PM
Both of those links are the same part number, 213928. That should be the right one, as long as that plug style matches your plug. That temp sensor tells the computer when to switch from open loop to closed loop. Has your engine been running kinda rich lately? rockauto.com has the same one for 8 bucks less, plus shipping though. But you can search it there for your own peace of mind, to show that sensor comes up as a fit.
Old Aug 31, 2010 | 07:39 PM
microkid's Avatar
March 2011 ROTM
lol, my engine hasnt been running for 3 years. it didnt run rich, it just didnt start below 40 degrees. i could squirt a bit of gas in the intake or eather, and it would then start. there is a difference though in the plug between those two listings, but that should be the one right? there are a total of 4 temp sensors on the 86 tpi
Old Aug 31, 2010 | 11:00 PM
I don't see a difference in the plugs between the two, and the part numbers are the same. If the plugs had a physical difference, for a different fit/application, they would have different part numbers.
Old Sep 2, 2010 | 08:40 PM
microkid's Avatar
March 2011 ROTM
thats what i was figuring. i was just going by the description. i think im going to try to find one in a junkyard and pull it off, then try to match it up with my harness, then get a new one
RdBlock
82-92 V6 Tech
Apr 14, 2014 09:59 AM
Mitch Upton
67-69 V8 Tech
Sep 9, 2011 04:04 PM
3.4camaro
Oct 19, 2009 07:14 PM
Alphons
70-81 V8 Tech
Sep 15, 2009 10:02 PM
XReply
Aug 16, 2008 03:40 PM
