manual trans.
Old Jun 27, 2006 | 01:15 AM
brock417's Avatar
Default manual trans.
hey everyone im new to the forums... and i have a 99 ss.. i like it and all but its an automatic.. i want to either make it a manual or buy a different camaro (probably at a junkyard) and fix it up... i was just wondering what everyone thinks the best, cheapest and easiest would be... i do have another car that i can drive in the time that the transmission is being swaped...
thanks for the help
Brock
Old Jun 27, 2006 | 11:20 AM
Default RE: manual trans.
The swap is easy. Y ou will need a trans, cross memeber, pedals, lines, slave cyclinder and thats about it. You will need a retune of the ECU as well. OR you could put a 3500 rpm stall in your auto and drop about 1/3 second in the 1/4 and make the car a ton more fun. With these cars the autos are alot eaiser to make fast in the 1/4 than the M6.
Old Jun 27, 2006 | 12:57 PM
YouLost's Avatar
Id stick with auto, After I drove a 6 spd at the track, I liked my auto a lot more
Old Jun 27, 2006 | 05:19 PM
brock417's Avatar
thanks for the ideas.... how hard is it to put in a rpm stall? and does anyone know what the stock transmission is in a 1999 ss
Old Jun 27, 2006 | 09:14 PM
You have a 4L60E trans, and a stall swap is pretty easy, you have to pull the trans and thats about it.
Old Jun 27, 2006 | 10:06 PM
brock417's Avatar
ok... what brand do you recommend? and what kind of tuning is envolved?
Old Jun 30, 2006 | 04:35 PM
I like Yank or Precision Industries, Fuddle has good following but I have no personal experiance with them. Figure on spending about $800 for the coverter and another $200 for a TCI flex plate (reccomneded but not 100% needed). The ECU will need tuning with either HP tuners or LS1 Edit to make the shifts hit right and get the most out the converter.
pobasturd
Dec 14, 2012 11:30 PM
olered
Nov 13, 2011 08:52 PM
pimpjuicepd
Jun 13, 2008 12:44 AM
sewerrat
May 3, 2007 12:28 AM
81TT
Mar 21, 2006 12:47 PM
