How do u replace a Ignition in a 77 camaro?
Old Nov 20, 2009 | 06:31 PM
Wyo77camaro's Avatar
Default How do u replace a Ignition in a 77 camaro?
Im tired of using a screw driver to start my car. Ive got a new switch already just not sure how to install it. Do u just pull the steering wheel and slap it in??
J.
Old Nov 20, 2009 | 07:00 PM
Pablo63's Avatar
Banned
From: Raised in Tilton NH now residing in Kings Mountain KY
Remove the wheel. Hazard button. Compress the lock plate and remove retainer clip from shaft. Unscrew and remove turn signal arm. Unscrew the turn signal assembly and ease it up off shaft and turn out of your way. The lock will be either held in with a screw or have a tab which locks into the column when inserted. If held in with a screw just remove screw and work the old lock out. If yours is held in with a tab you will have to insert a small thin screwdriver or the like into a small slot to release the lock. Once the old one is out just slide the new one into place and reverse the steps. Job is alot easier with proper tools.
Old Nov 21, 2009 | 08:43 AM
thanks bro. ill try it i fill like im stealing my own car sometimes lol
J.
Old Nov 21, 2009 | 03:22 PM
Got my new switch put in. Tough part was getting that darn snap ring back in, while tryin to compress the clock spring. Now to get my wireing fixed.
J.
NOLAcamaro
Mar 5, 2012 08:28 AM
camaroman18
Jun 11, 2010 04:25 PM
camaroman18
Jun 7, 2010 09:24 PM
Trippin15
82-92 V6 Tech
Nov 9, 2009 09:44 PM
RieskeKR
Jul 18, 2005 06:55 PM
