'92 Camaro Hatch Question
Old Mar 15, 2005 | 03:31 AM
Mike92NY's Avatar
Default '92 Camaro Hatch Question
Hello all......
From what I've come to understand, there were 40,000+ hatch release buttons on the '92 Camaro. I just bought this car 2 months back and am curious if mine has it and if it does, where is it located?
Old Mar 15, 2005 | 09:37 AM
DarkBirdZ28's Avatar
Default RE: '92 Camaro Hatch Question
most of the hatch release buttons were located on the console or somewhere around the gauge cluster
Old Mar 15, 2005 | 11:29 AM
Mike92NY's Avatar
Ok cool, I'll take a look this morning and hopefully the original owner didn't skip on that option.
I bought the car for 1k from one of those Auto Donation For Charity places and so far the only thing I need to replace if the oil pan(bought it, have to install it next week).
The salesman had lost the door/hatch key so I hope for the best when I take it out that no one is going to jack it or lift parts from it. I've gone to two locksmiths and they both told me that they'l have to strip the door down to install a new lock. I was like WTF?, and then told them that this was a Camaro and not some crappy little honda and they just shrugged.
I guess the only safe bet is at the Chevy dealer, but I have a feeling that's gona run a few hundred bucks.
Old Mar 15, 2005 | 04:55 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
to replace the locks?? u can get the whole set with keys from classic industries, or a decent locksmith could make you th ekey for it
Old Mar 15, 2005 | 07:25 PM
Mike92NY's Avatar
Ok, I'll keep looking for a good locksmith. On a side note....I looked for close to twenty minutes today for that hatch release, but it's no where to be found, and there's no key hole to open it?
This is so bizarre, where the hell is this thing?
Old Mar 16, 2005 | 06:10 PM
nj85z28's Avatar
February 2012 ROTM
May 2012 ROTM
no keyhole? shouldnt it be behind the liscense plate? otherwise if you do have the release it would be between the power window buttons i think
Old Mar 16, 2005 | 07:35 PM
Mike92NY's Avatar
The license plate won't move; it's bolted onto the back of the Camaro in its proper spot, and the assembly won't move either. This sucks!
I'll do some more hunting tomorrow. Thanks for the suggestions so far.
Old Mar 17, 2005 | 09:27 AM
ok here's what you gotta do. it sounds like the plate holder is rusted to that position. get some rust penetraiter and put it on the hinges at the bottom of the plate holdergive it a minute to soak in and the start trying to move it. and to tell you now they arent going to be able to help you in a dealer unless you take one of the lock sylenoids out. if you do that then it would be alot easier on everyone and you would get your key. locksmiths have to take the lock sylenoid out so they can cut a key. all you have to do is take the door panel off and then take the spacers out that hold in place. then you need to just take it out.
Old Mar 17, 2005 | 07:18 PM
nj85z28's Avatar
February 2012 ROTM
May 2012 ROTM
just spend the 30 dollars and get the whole lock set, change all 3 locks and be done with it
Old May 25, 2005 | 11:21 AM
91z 4yrs in d making's Avatar
go to autozone and get new locks. there cheeper than a lock smith and there easy enough that you can do it yourself..
wifeys92rs
Mar 16, 2013 09:30 AM
mcd
Mar 3, 2012 10:40 AM
Mikey.
Feb 19, 2012 03:36 PM
oneals camaro
May 5, 2008 06:56 AM
