1996 Z28 Hesitation
Old Nov 19, 2009 | 01:25 PM
octain01's Avatar
Default 1996 Z28 Hesitation
ok, lets see if I can get some help from the pros! My Z28 run and shifts fine when you are driving normal. When you first start it up, the RPMs will go way low, acting like its going to die, then after a few seconds it brings the RPMs back up and runs fine. Also when I accelearte hard, the car hesitates at high RPMs before shifting. Any idea on what the problem might be? Im going to replace the plugs this weekend, but I dont think thats what it is. IDK tho, this is my first camaro.
Thanks
Old Nov 19, 2009 | 02:46 PM
check the plug wires while your doin the plugs. has the opti ever been replaced?
Old Nov 19, 2009 | 06:13 PM
octain01's Avatar
I believe the opti has never been replaced, but I have been reading up on this. Is there a way to look at it and tell if it is bad?
Old Nov 19, 2009 | 07:24 PM
no not really. if the car runs then everything will check out on the opti and thats if u have the equipment to test it. the optic reader is what goes i guess. when mine was going i took it out and opened it to find rust on anything metal. how many miles on the car? i think 130k is about the average give or take 25k. lol. anyway if u take it apart so u can look at it then u might as well replace it. and the water pump as far as that goes. i was very surprised the first time i looked under the hood for the distributor. finally found a plug wire and followed it. lol.
Old Nov 19, 2009 | 10:32 PM
octain01's Avatar
lol well if around 130k is when they go, I guess mine is gone. I have 162k on the car. lol Ill let you know what happens when I change the plugs. Ill go ahead and replace the wires as well. Thanks for the info!
cadmanof50s
Aug 1, 2011 10:42 PM
ryan88z
Mar 26, 2008 10:51 PM
toml14
Mar 29, 2007 02:34 AM
soulonfire11
Jan 14, 2007 02:13 PM
got3ofem
Nov 29, 2006 08:43 PM
