Crankshaft Pulley
Old Oct 27, 2009 | 10:06 PM
uestraven's Avatar
Default Crankshaft Pulley
My crankshaft pulley has the three bolts around and one center bolt. I removed the three outer bolts but when I try to loosen the middle, it just turns the motor. Do I need a puller or can this be done somehow else?
Old Jan 8, 2010 | 08:31 AM
A safer way is to remove the bell housing cover and grab the flywheel or flex plate and use a pry bar, screwdriver, etc and jam it from turning, and then loosen the bolt. Also, a good impact wrench will get it off without spinning the engine. Once the bolt is off, you will still need a puller to get the damper off.
Old Jan 8, 2010 | 08:43 AM
johnritchie30's Avatar
a trick that works great for me is to remove a spark plug, then feed a length of small rope through the spark plug hole. make sure to leave the end accessible to pull the rope out. as the engine turns the rope fills the cylinder to stop the turning and due to the rope being soft it wont damage any components.
Old Jan 8, 2010 | 09:13 PM
Just open the bottom of the bellhousing, then take a pair of vise grips or a C clamp and clamp it on the flywheel or flexplate. You can now safely turn the crankshaft bolt out. It might turn a little until the vise grip hits the bellhousing, but then it will stop.
H3llboy676
Mar 8, 2012 08:36 PM
fasttony350
Feb 18, 2012 04:50 PM
hawkins183
Feb 15, 2012 10:50 AM
benz660r
Aug 9, 2006 12:12 AM
GR95Camaro
Mar 25, 2006 06:17 PM
