LS3 engine swap
Old Oct 12, 2009 | 07:32 PM
stovebolt_six's Avatar
Default LS3 engine swap
Hello all,
I currently own a 69 camaro with a non numbers matching 350. I'm interested in swapping in an LS3. Has anyone completed a swap like this, and if so, what all would I need? Any assistance will be greatly appreciated. Thanks in advance.....Clint
Old Oct 13, 2009 | 10:15 PM
bohuntr's Avatar
i have swapped a fuel injected LT1 into a jeep cj7....it cant be that much different as far as finding motor mounts,fan setup,exhaust,bellhousing...etc....that part was easy...if your planning on swapping the ls3 and the computer into it...getting the codes and stuff to work with the camaros wiring may be an issue(as it was with my swap)...im assuming your planning on the fuel injection and computer stuff to go with it....the LS3 is an awesome engine....i wish u luck
bohuntr
Old Oct 27, 2009 | 12:33 PM
68 TT's Avatar
This site will answer every question you could possibly have about the swap.
http://www.ls1tech.com/forums/conversions-hybrids-28/
Old Oct 28, 2009 | 11:17 AM
tazinhawaii's Avatar
June 2011 ROTM
2011 RIDE OF THE YEAR
I have done this to my 69. LS3, 4L80E, dana 60, etc. There are a BUTT TON of pics in the "sticky" link here under "members projects". It's actually not too difficult of a swap if you're familiar with the LS series of engines. I bought my motor, accessories, trans, computer, harnesses, etc., etc. through a place on e-bay for $10.5K. With a 1 year warrantee (motor was new). If you have any questions on the swap please ask. But it's great having a car with the 69 body, but runs like a new vette just off the dealers lot.
Derrick
Here's a link to the photos of the car and build.
http://s330.photobucket.com/albums/l...i/69%20Camaro/
Old Nov 8, 2009 | 09:25 PM
skips69's Avatar
I just went to the Sema show in Las Vegas this week. GM Performance parts has a new LS3 engine out specifically for Muscle cars. Costs $8000.00
Old May 22, 2010 | 06:40 PM
steve671's Avatar
I am doing the same to my 69 as well. Can you tell me what oil pan was used with your engine? I got my LS3 out of a 2010 Camaro and have oil pan to crossmember clearance issues.
Thanks,
Steve
Old May 24, 2010 | 04:43 PM
June 2011 ROTM
I did the entire BRP setup. I DON'T recommend it now though. I used the Hummer H2 pan. If you go that route, I recommend going through GM directly (cheaper than the 'specialty' place I got mine by over $100). I know summit even sells kits to install the LS engines now so that may be a way to make it easy. The header fitment is the other clearance issue you may have to deal with if you piece together different parts... You'll have enough engineering parts during the rest of the swap to have to worry about these issues....
Derrick
Old May 25, 2010 | 02:27 AM
steve671's Avatar
Derrick
Thanks for the info Derrick. What headers did you end up going with?
Old May 29, 2010 | 07:11 PM
June 2011 ROTM
The 1-7/8" headers from BRP. They are actually Headman headers though. I did learn that if you go with 1-3/4" headers, that's actually smaller than the exhaust port on the LS-3 so go with the 1-7/8.
Derrick
3800_seriesII
Aug 14, 2012 07:24 AM
jrb78
11
Dec 16, 2007 07:05 PM
cachaco736
Dec 11, 2007 11:12 AM
uradumass5695
Oct 21, 2006 08:27 AM
illumastar
Oct 20, 2006 01:42 PM
