Overdrive transmissions ?
Old Oct 8, 2009 | 08:13 PM
juggernaut's Avatar
Default Overdrive transmissions ?
hi, I have a 67' currently running a th400 with 3.73 gears. So, I would like to install and overdrive transmission. The engine is a stroker 454 dyno'ed at 625 hp & 640ft/lbs. I like the gearvendors and usgears od units but they're a bit pricey, bteracing has 700r4's and 4l60e's for half the price or maybe a 4l80e? Does anyone have any suggestions?
thanks, landon
Old Oct 9, 2009 | 03:37 PM
mcmcmahon's Avatar
Here check out this article http://www.superchevy.com/technical/...ive/index.html I think this explains what is involved with swap. if you go with a electronic trans ,you will need to buy a controller for it also.
Old Oct 11, 2009 | 04:54 PM
tazinhawaii's Avatar
June 2011 ROTM
2011 RIDE OF THE YEAR
With that much torque, I'd go with the 4L80E if you go that route. I went through 2 4L65E's in 700 miles with a relatively stock LS3 in my 69 Camaro. The 80 has held up GREAT though. I am running the TCI controller as well with no problems. I got the 80 from a junk yard of all things as well, so it only cost about $1K for the trans/computer/driveshaft... The only "smart" purchase I think I've made.
Derrick
Old Oct 11, 2009 | 05:40 PM
Originally Posted by tazinhawaii
...The only "smart" purchase I think I've made.
Derrick
Ahem, in addition to the 69 Camaro, of course!
Old Oct 13, 2009 | 10:58 PM
1969 SS's Avatar
anything newer than the 700R4, you're going to have to get a computer also. it might be worth completely pricing out all your options and see how they stack up once everything is included
with those types of numbers, I'd be afraid of a junkyard tranny
Old Oct 27, 2009 | 12:30 PM
68 TT's Avatar
With the torque you are making the 4L80E is the best option. You will destroy any 700R4 / 4L60. A 200-4R like they use in the Grand National can be built to handle a lot but you may be beyond it's capability too.
You can cut the cost of the transplant a bit by going with a full manual valve body conversion. No expensive transmission control computer to deal with but you have to manually shift every gear all the time.
The 91 to 93 GM diesel trucks had a stand alone transmission controller that can be used to retrofit the 4L80E and maintain full automatic functions.
pondo1000
Sep 26, 2011 03:02 PM
pondo1000
Sep 26, 2011 07:44 AM
JordanN
Mar 7, 2010 03:57 PM
GoofieJ21
Jan 30, 2009 12:35 AM
3RDGENZ28TX
May 24, 2007 12:18 PM
