Corvette parts in a Camaro
Old May 25, 2006 | 07:17 PM
Vampirex's Avatar
Default Corvette parts in a Camaro
Does anyone know What parts from a C5 or C6 Corvette can be used on a late model LS1 01-02 Camaro?
Because ive herd that you can use like the intake system and mabye even exhaust
Old May 25, 2006 | 10:06 PM
Default RE: Corvette parts in a Camaro
The LS1 in the C5 engine is the exact same as the LS1 in the F-body. Why would you want to put exaust manifolds from a Vette on a Camaro, when you put on headers that will give even more power? As for the C6 it has the LS2 in and it is the exact same engine that the 05 and up GTO has. One thing that the LS2 does have that is a good upgrade is the LS6 heads that were formerly only avalible on the Z06 Vette. Vettes don't really have anythign special on them unless it is a Z06. Even then the after market has parts that will give you much power. (LS7 and C5/C5R stuff excluded)
Old May 26, 2006 | 02:15 PM
Vampirex's Avatar
oh i see, it was only a rumor I came across.
I have been thinking about putting on new headers already
Any suggestions on what make/size?
Old Jun 6, 2006 | 09:43 PM
Lil_427's Avatar
Hooker, the more flow the better
kurry89
Mar 10, 2011 09:51 PM
dustinb
Jul 6, 2007 02:28 PM
CamaroKid16
Jan 9, 2007 04:08 PM
simple_john
Mar 15, 2005 02:53 AM
