engines
Old May 22, 2006 | 04:49 PM
thadd154's Avatar
Default engines
what is the difference between the LT1, LT4, LS1, LS4 other than the LS's have more poneys and were made later.(i.e. head angles ect.)
Old May 23, 2006 | 07:45 PM
Default RE: engines
The Lt1 & Lt4 were based on the Chevy small block, but have reverse cooling and a front cover mounted distributor. and they come in two sizes and many HP variations. They use cast iron blocks, and the heads can be either cast iron or aluminum. The LS family replaced the original small block, and is an entirely different engine with very few parts that can be interchanged with the older engines. The LS engines come in various sizes, and are used in trucks and cars, some are all aluminum, and some have cast iron blocks. HP ratings range up to 504 HP.
Swiftpain
Dec 18, 2009 01:21 PM
PseudoKirby
12
Mar 5, 2009 12:22 PM
JHL88
Mar 13, 2007 10:34 PM
mossport777
Feb 12, 2007 10:09 PM
