Ls1 to Ls6 intake help
Old Aug 7, 2009 | 03:19 PM
maudyZ28's Avatar
Default Ls1 to Ls6 intake help
ok people, i know this has been talked about before and i read all the posts on gains etc as i plan to cam and heads later BUT!!! whats all this about the a 99 ls1 needs to alter the coolant hoses (metal ones?) as the ls6 manifold is not a direct swap!
thanks
Old Aug 16, 2009 | 08:54 AM
Roachz28's Avatar
hmm I wonder what it is like on an '02. i am going to be doin this mod during the winter months this year so im kinda curious as well.
Old Aug 17, 2009 | 06:59 PM
98Z's Avatar
98Z
I'm new here and was also wondering about this swap. But not about the coolant lines. I've read about that. How do you eliminate the egr on a 98? Won't that affect the timing when on the interstate?
Old Aug 18, 2009 | 06:08 PM
sk8rax350's Avatar
Well, to have the EGR completely removed, without getting a SES light, you'd have to tune it out of your ECU. After that it's cake! Assuming you're getting an LS6 intake, you'll already have it removed from the intake. All you have left is two bolts on the exhaust manifold, and two bolts holding in onto your head. It comes right off! But, in order to not have an exhaust leak, you'll have to get something to block off where you just removed your EGR from the exhaust manifold. All I did was fabricate a steel plate to put directly over it, and a thicker aluminum plate to go over the steel one. Surprisingly enough, the old EGR gasket served as a good one to use for the block off, with no leaks. It definately looks a lot better under the hood without the EGR there!
As far as the timing goes, I'm not completely sure, but I don't think it would make too much of a difference, if any, because the 2001 and 2002 Camaros don't even have the EGR.
I just never liked the sound of putting your exhaust gas into the intake!
I bought my SS with an LS6 intake on it already, so I'm not sure what the whole deal is about the coolant lines. I do know that mine does have a piece of line that is metal behind the left fan though.
Old Oct 11, 2009 | 08:44 PM
KPI's Avatar
KPI
The manifold itself is a direct swap. The 01-02 Camaro with LS6 intakes have the rear of each head capped whereas the LS1 has a coolant line that runs side to side in the rear. As already mentioned, the LS6 mani doesn't have an EGR.
Old Oct 12, 2009 | 07:13 AM
maudyZ28's Avatar
yer i eventuall found a really good write up here, we have (ls1 intake) and X shaped coolant pipe running left to right, front to back. LS6 only use the front crossover.
http://www.ls1howto.com/index.php?article=5
crimson09
Dec 15, 2018 07:07 AM
carid
Vendor Special Buys
Jan 20, 2015 07:08 AM
antbradley100
Mar 12, 2011 05:11 AM
tuletymeZ28
Aug 22, 2010 12:12 PM
z28rob18
Jun 22, 2009 04:40 PM
