Whats the difference in y-pipes?
Old Mar 24, 2006 | 04:17 PM
jarid2000's Avatar
Default Whats the difference in y-pipes?
What the difference between the factory y-pipe on my 2000 Z28, from an aftermarket 2.5" y-pipe? Let me know anything. I want to upgrade, but I'm not sure if it's worth it. Thanks.
Old Mar 24, 2006 | 07:10 PM
TimmyTheWop89's Avatar
Default RE: Whats the difference in y-pipes?
the pipe diameter is probably a little bigger, but also, where the second pipe joins the forst, is a lot smoother merge point. some y-pipes jsut have a normal pipe comeing from one end of the motor, and the other pipe is jsut welded in from a 90 degree angle so it creates turbulence. an aftermarket y-pipe joins the two pipes in teh same direction, so the airflow is a lot smoother, thereofr making more power.
Old Mar 24, 2006 | 07:22 PM
The stock LS1 y-pipe is flattened out on the drivers side, this causes a restriction. My advice though is to get headers along with the y-pipe, this will give you the best gains.
A2TURBO
Oct 6, 2012 11:53 AM
dlaidoutranger
Oct 4, 2012 11:36 AM
nkramirez7
10
Jun 12, 2007 11:04 AM
02CamaroV6
Oct 25, 2006 10:07 PM
andremvp8
Sep 21, 2006 07:42 PM
