Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
whats the difference in NOS
Old May 30, 2007 | 11:59 PM
nkramirez7's Avatar
Default whats the difference in NOS
with Dry and Wet...whats better? I have a 2000 v6 camaro
Old Jun 1, 2007 | 10:37 PM
nickdotcom's Avatar
Default RE: whats the difference in NOS
dry uses your computer to add more fuel
wet injects fuel with the nitrous
better is a matter of opinion
Old Jun 1, 2007 | 11:30 PM
badinfluenceRS's Avatar
dry kit's also inject nitrous into the fuel system (just to clarify)
I was told a dry kit would be easier to install
Old Jun 2, 2007 | 01:27 AM
nkramirez7's Avatar
but what would be easier on the engine?
Old Jun 2, 2007 | 09:07 AM
I'm sure there is not a great difference between the two....
I was TOLD that a wet kit would be a little safer, just going of what i've heard
Old Jun 2, 2007 | 03:15 PM
nickdotcom's Avatar
depends on what size shot you want
when i did the research for nitrous i decided to go wet
im just a kid by most of yalls standards and the install was very easy, the wiring was the hardest part and it wasn't even that bad. i was triple checking all my connections so it was a bit time consuming.
Old Jun 2, 2007 | 10:04 PM
nkramirez7's Avatar
ok cool thanks, i appreciate the info
Old Jun 6, 2007 | 07:46 AM
CamaroKid16's Avatar
Wet nitrous systems will be alil more difficult, but you can get pretty much any amount of power you want out of it. In the v6... dry would be sufficent, just because you're never going to want to go over 150 EVER!! I'm choosing to go with the dry and put about 75 shot in.The install... pretty easy, just follow instructions!
Old Jun 6, 2007 | 05:07 PM
Lee Willis's Avatar
ORIGINAL: badinfluenceRS
Really, I've installed and fiddled with dozens of dry kits and never seen one that does anything, much less "injects" NOS or anything else into the fuel system. A dry kit injects the NOS gas into the incoming air somewhere upstream of the MAF so that the NOS, mixed with the incoming air, is measured by the MAF, and the additional mass is interpreted as more air, and thus results in the ECM injecting additional fuel. It works well when you are trying to add no more than about 33% additional power from the NOS, after than injection spray duration and other factors make it best to go to a wet kit, which squirts fuel into the intake manifold near the ports while also shooting NOS into the intake manifold.
Dry kits are a big advantage because:
a) they are cheaper and easier to install, you don't have to do a thing to the fuel system - just leave it alone: fewer parts to install, less time to install.
b) they are safer: the additional fuel lines, pumps and fuel injectors of a wet system often leak and start fires
c) they are easier to tune: wet kits can take 2 to 3 times the dyno time to get perfect A/F ratio and no ECM back-off ocsillations
d) they are easier to hide: a lot of street racers hide the system so they can claim they have no NOS and even open the hood to prove it. I've done it myself.
Old Jun 9, 2007 | 02:46 PM
LEE pretty much took care of it all. Nice info LEE!!!
