suspension
Old Nov 27, 2007 | 07:21 AM
1stgenssclone's Avatar
Default suspension
1968 camaro front springs have the car setting 3 in above tire
i assume the disc front end is from a 69
the car does not look or drive right
i bought the car the same way i cut 1 coil and it looked good and drove fine but i do not want to change front rims to a diferent off set every bump the wheel rubs the fender
bought new springs for a 69 with 350 w a/c and ist the same before i started
hhhhhhhhhhhhelp please
Old Nov 27, 2007 | 07:33 PM
justincat's Avatar
Default RE: suspension
look at your old springs that are a little to low, and your new springs that are to high. Put them side by side and cut them longer than the ones you already cut. dont cut them to short because you can always cut some more off later.
Old Dec 6, 2007 | 01:28 PM
Blade's Avatar
June 2007 ROTM
dont not cut ur springs. how about convert it over to coilovers? AND DO NOT GO WITH DROP SPINDLES
Boog1313
May 6, 2013 11:39 PM
97Beast
Aug 6, 2011 07:20 PM
MusicMan
Feb 21, 2009 11:01 AM
99camaro00
Jul 14, 2008 07:48 PM
nuttyprofessor
Oct 1, 2007 05:41 PM
