removing scratches
Old Nov 11, 2007 | 01:53 PM
jordanreign's Avatar
Default removing scratches
I took off my door guards on my 01 ss. I could not get the glue off so for some stupid reason I lightly scrubbed at the door with the rough surface of a sponge. it left inch wide scratches down my door. the scratches do not go threw the paint but it just looks dull. i used turtle wax scratch remover and compound rub and wax. does anyone know if any thing else will actually work.
Old Nov 11, 2007 | 07:24 PM
Default RE: removing scratches
Sounds like you took the clear coat off & it's not going to really shine till it is put back, but you can try white rubbing compound and a good coat of wax.
Old Nov 30, 2007 | 01:44 PM
LT1RUNNER's Avatar
You can also try wet sand it with 1200 or higher and then use a polishing/compound.
Old Jan 19, 2008 | 07:22 PM
1stgenssclone's Avatar
OK THEN!
mlb5769
Sep 29, 2011 11:48 AM
th3po1son
Nov 10, 2007 03:45 PM
shiby4ever
Sep 18, 2006 12:40 AM
shiby4ever
Mar 30, 2006 02:41 PM
