manual transmission mount
Old Sep 8, 2004 | 11:27 PM
crhumper's Avatar
Default manual transmission mount
my cousin has a '92 camaro rs with a 3.1 v6 and a manual trans(t5?). we found that his transmission mount needed to be replaced, but its a dealer only part...$150. has anyone here modified there crossmember to accept an automatic transmission mount?? we were thinking about using a polyurethane mount from energy suspension. the main thing i'm concerned about is the correct distance from the bottom of the transmission to the crossmember. i figured i could weld a plate in the crossmember and then drill two holes to mate up with the auto mount. i'm sure if we do this it will just be trial and error basically, but was curious if anyone has run across a similar problem. any other suggestions would be greatly appreciated. sorry for the long post
humper
Brandon96z28
Mar 21, 2011 11:14 AM
sp9o3
Feb 8, 2009 08:46 PM
DeputyDog
May 21, 2008 09:49 PM
wilbglc
Apr 6, 2007 09:38 PM
