12 bolt rear end
Old Mar 21, 2007 | 01:46 PM
MnM7981's Avatar
Default 12 bolt rear end
Hello guys. I am new to the forum here and any help would be much appreciated.
Right now I have a 67 Camaro with a 327and a 10 bolt rear end. I am not sure on the transmission. I was told it was a TH400 but it could be a TH350. If have heard you can use the 10 bolt, but a 12 bolt is a much better option. what do you guys think.
I would also like toknow what gears you would recomend. The car would bemainly for the street with an occasional trip down the track for fun.
Thanks in advance for your help.
Old Mar 21, 2007 | 02:10 PM
GRIFF's Avatar
Default RE: 12 bolt rear end
How important is cost?
Old Mar 21, 2007 | 02:42 PM
Ratman's Avatar
I've raced similar cars for years. Any thing beyond a 4:11 will be dificult to drive on the street. The 10 bolt will probably work with an auto matic. If you run slicks
over 28" you will blow the spider gears. The spider gears are the weakest link in the drive train. How fast do you want to go?
Old Mar 23, 2007 | 02:14 PM
skar's Avatar
MnM7981
I am in the same spot. DTS and others told me a 10 bolt would be OK with street tires. With a auto as long as you are not to hard on it. No back to back burn outs (don't heat up the tires)
I would not go to the track with a 10 bolt. I was told when a 10 bolt goes so does sheet metal.( Fenders)
MusicMan
Sep 29, 2008 06:25 PM
nzink
Apr 4, 2008 01:29 AM
mcge383
Nov 7, 2006 09:56 PM
cabowaboz28
Jul 29, 2006 01:58 AM
