engine swap 2.8-350 carb
Old Apr 6, 2004 | 06:51 PM
slowmaro2.8's Avatar
Default engine swap 2.8-350 carb
swapping a 2.8 for a 350 carb on an 88 got any tips on changes???
Old Feb 15, 2005 | 11:10 PM
z28srule's Avatar
Default RE: engine swap 2.8-350 carb
make sure you check weather the drive shaft is long enough for what ever size tranny you use.
the engine will bolt up the the set of holes right in front of the original motor mounts. What kinda transmission did the car have?auto or stick? If you like hot roding it around you may want to change out the rear end with one from a v8 camaro
Old Feb 16, 2005 | 03:05 AM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
youd have to change everything.....cpu n all
Old Feb 16, 2005 | 03:30 AM
z28srule's Avatar
you wouldn't have to if your working anywhere from 1982 to 1989 expecially if your going to use a carburated engine
Old Feb 16, 2005 | 03:54 PM
nj85z28's Avatar
February 2012 ROTM
May 2012 ROTM
are 2.8 motor mounts going to hold a 350? will the suspension handle it> if its an auto trans, will it handle it?? the exhaust def. wont and neither will the rear. plus if its fuel injected, youd have to change the fuel pump so you dont kill your carb
Old Feb 16, 2005 | 06:55 PM
z28srule's Avatar
your right you'd have to change the suspesion and the transmission but if you have motor mounts for the 350 you can use them they will line right up to the first set of holes if you change from fuel injection you will have to get a fuel pump that is the right size for your engine if its not you won't kill your carb you use lots fuel and flood your engine alot i'd know this i had that problem in my 87 sport coupe. now you'll have to change the tranny and you'll have to use one made for a camaro with a torgue bar it will most likely be a th-350 or a 700-r4 the stock mounts won't do you'll have to change the crossmember to one for a v8 camaro other that that most everthing else works but if you still don't think so keep asking questions about wether certian things match up and i'll tell you
Old Feb 16, 2005 | 10:11 PM
nj85z28's Avatar
February 2012 ROTM
May 2012 ROTM
with all the work involved, just sell it and buy a camaro with a V8....you'll spend a rediculous amount to change all of that
Old Feb 17, 2005 | 01:23 AM
z28srule's Avatar
no it doesn't trust me a put a 350 in my camaro and it had a 2.8
Old Feb 17, 2005 | 08:19 PM
nj85z28's Avatar
February 2012 ROTM
May 2012 ROTM
and about how much did you spend, considering you can get a perfectly fine running V8 between 500-1500$
looker44
Jun 27, 2013 05:11 PM
NapolitanoZ28
May 22, 2011 11:11 PM
Bear
Jun 19, 2008 10:27 PM
Auji350
Sep 5, 2007 07:36 PM
jcollins91106
Nov 10, 2006 05:35 PM
