89 350 tbi to carb swap
Old Jun 6, 2013 | 12:09 AM
looker44's Avatar
Default 89 350 tbi to carb swap
I have a 350 from a 89 caprice I'm swapping into a 96 camaro in place of the v6 I'm wanting to do this on a budget and I was wondering if anyone has ever done this and what parts they went with any help would be appreciated Thanks
Old Jun 27, 2013 | 05:11 PM
firebird56265's Avatar
Hi Bud
Just a quick note to say that I did this swopp on a 92 rs. Pulled out the 305 and replaced it with a 350 out of a 92 suburban. I went with a 670 street avenger holley and a edlbrock performer intake. as far as your fuel pump goes you can eather go with a mech. or just use the pump in the tank,but with one mod. you have to use a press. regulator that is adjustable and that has a fuel return or you will burn out the pump in the tank and we all know how much fun that is to replace. The reg. I used was from holley. About $68.00 at o-Riely's if I remember right. I went with a standard HEI distributor and used the hot ign. wire from the TBI ignition system to run it. all has worked out very good.
Good luck to you!!!!
NapolitanoZ28
May 22, 2011 11:11 PM
jjusseaume
Sep 2, 2010 06:50 AM
bobarian91
Nov 5, 2008 10:47 AM
theFLoYD1964
82-92 V8 Tech
Oct 21, 2007 11:32 PM
Gordon24Camaro
Feb 3, 2007 12:55 AM
