400 small block
Old Jul 29, 2005 | 11:37 PM
romero's Avatar
Default 400 small block
Hey all you gear heads, what's up? I have a question about swapping engines. I have a 1981 Z28 with the 305 HO and the muncie four speed. Could someone tell me if the 400 will bolt up to the tranny or do I have to modify something. Anyone with some info I would be thankful.
Old Jul 30, 2005 | 01:29 AM
70bigblock's Avatar
Default RE: 400 small block
if its a chevy 400 then it will bolt right up with no modifications needed. Has long use the 400 flywheel you should be fine. Good luck
snopro_16
67-69 V8 Tech
14
Aug 23, 2022 04:08 PM
decaen
Feb 16, 2012 01:08 AM
gadmhahn
Oct 9, 2009 09:20 PM
acarius
Apr 7, 2009 05:53 PM
Carinhas
67-69 V8 Tech
13
Aug 23, 2007 05:02 PM
