New Engine Help
Old Jul 27, 2005 | 04:29 PM
camarogirl97's Avatar
Default New Engine Help
I just got a new engine put in my 97 v6, and i've put about 1,000 miles on the new motor so far. It doesn't seem to have very much get-up. I understand that it doesnt have a whole lot of get-up-and-go because its only a 6 cylinder but my last engine had a heck of a lot more power then this one does. Is it just because it's a new engine and it needs to get broke in or what? I was on the highway today and a freakin Plymouth Breeze blew me outta the water...what the heck??
Old Jul 28, 2005 | 05:26 PM
Default RE: New Engine Help
Is the check engine light on? By 1000 miles the engine is as broke in as it ever will be.
Old Jul 29, 2005 | 12:23 AM
Yeah it's funny you mentioned that..my check engine light is on..but i took it down to the mechanic who put my engine in..and he said that it was the 02 sensor that was bad.. for my exshaust... so i dont know... it just seems like its missing a little bit.
Old Jul 29, 2005 | 12:20 PM
Heres the thing with the CEL (check engine light) in the newer Camaros. Any time that light is on it sends the computor into what is called limp mode, basicly it is a default setting setting that is ultra safe, they did this so that you could drive the car to the shop without really hurting it. If the O2 sensor is indeed bad that will send the computor into a fit and the results will be things like a loss of HP and poor gas milage.
Old Jul 29, 2005 | 04:00 PM
69rat's Avatar
with a bad O2 sensor it could be tilling your car to run very lean or very rich. i would replace that soon. and watch out for those plymouths
Old Jul 31, 2005 | 04:53 PM
Thanx for the advice.. I'm working on replacing the sensor, but those bad boys arent cheap. So do you think that is the answer to my question?? Getting that replaced then i should be good??
Old Dec 23, 2005 | 06:11 PM
mattvogt's Avatar
its worth a shot. If your doubtful, take it to a second mechanic for another opinion.
onefastls1
Jan 2, 2013 01:45 PM
martynlutherking
May 25, 2010 11:12 PM
Chevykicksbut
Oct 28, 2009 07:14 AM
drabina
Jul 25, 2008 08:56 PM
jrb78
11
Dec 16, 2007 07:05 PM
