Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
1979 camaro turbo help
Old 12-02-2011, 01:28 AM
acjjen4459's Avatar
Default 1979 camaro turbo help
hey guys, i have a '79 camaro with a 355 carburated motor in it and im wanting to put a single turbo set up on it, but, im not 100% on what i need ie. what size turbo, pistons, rods, crank, compression ratio etc.
if i could get some help/suggestions that would be fantastic.
thanks!
Old 01-04-2012, 04:48 PM
tommynos's Avatar
July 2007 ROTM
thanks!
theres hundreds of options depending on how much you want to spend..I mean hundreds!
Basic concept is a low compression of around 8-8 1/2,good forged crank and pistons..A turbo can be about anything you want depending on how much you want to spend and what style you want but I just have a set of 63s on mine from a grand national..car makes crazy power with no lag..have a good converter built for it and put in a turbo cam with a good blow threw carb or run big money fuel injection and your good..
Old 05-04-2012, 05:24 PM
cbr600rx7's Avatar
Cheap way to go here would be a roots type blower. Its going to be way cheaper and a lot less of a pain in the #$%. Depending on what kind of Compression you are running on the 355 you may be ready for boost.
79z28camaro
07-05-2010 10:38 PM
stilllearnin
07-15-2008 04:13 PM
79camaro79
06-05-2007 02:58 PM
abel.towle
11-07-2006 03:04 PM
Quick Reply: 1979 camaro turbo help
