Distributor connector
Thank you for the help and you are right. The harness wasn't swapped over but that's not why it won't run. It has a bad fuel pump and I'm not really in the mood to drop the tank and change it at the moment 😂😂 maybe sometime in a month or two but at least I know the crank sensor isn't there
use hatch mod to change fuel pump. much easier. https://camaroforums.com/forum/93-02...-method-63702/
if you want to make sure its only the fuel pump, take the air cleaner elbow off at the trottle body and give a squirt of starting fluid or better yet gas, lol, if you can figure out a way to squirt gas into the trottle body. then try to start. if it kicks over and starts or tries to run you know its not getting fuel and is wanting to run.
