LT1/LT4 Tech 1993-1997
383 block
Old 02-23-2013, 11:34 PM
carguylt1's Avatar
Default 383 block
I am building a 95 lt1 383 someone told me that the block does not have to be clearanced for the stroke. Does anyone know if this is true? Also need a good header bolt any suggestions? What thread size
Old 02-24-2013, 12:16 PM
greenmachine96's Avatar
You will know during preassembly and it likely will have to be clearanced some. ARP bolts are great
Old 02-24-2013, 05:15 PM
YAV8's Avatar
If your using stock rods the bolts on 1,2,5 and 6 on the inside will need to be clipped to clear the cam or get a small base cam. If you are using after market rods they will clear the cam. You will need at least .050 clearance between the block and the rod. If you can get a bushed rod or hone out a stock rod, put the piston on the rod with out rings and check for clearance before you start installeing the cam bearings and such. You might have a lot of cast iron floating around if you do some grinding for clearance.
decaen
02-16-2012 01:08 AM
tecumseh
03-08-2011 01:01 PM
gadmhahn
10-09-2009 09:20 PM
acarius
04-07-2009 05:53 PM
Carinhas
67-69 V8 Tech
13
08-23-2007 05:02 PM
Quick Reply: 383 block
