Water dripping from exhaust pipes
Old 11-29-2011, 07:27 PM
jessedgraham's Avatar
Default Water dripping from exhaust pipes
The exhaust pipes now drip water, on both sides equally. I have just water in my radiator right now. My engine has been in great shape. It's a 350 rebuilt with Edelbrock high rise manifold, in a 75 Camaro. I understand that this may be the coolant going into the manifold, and coming through the engine into the exhaust? What can I check for, what can I do?
Thanks!!
Old 11-29-2011, 08:18 PM
77 kencraft's Avatar
What are your other symptons, is the running ok are you loosing coolant, are you sure it's not just normal condensation
Old 11-29-2011, 10:49 PM
BasicConcepts's Avatar
Technical User
its most likely condensation due to the colder weather
Old 11-30-2011, 01:03 AM
Is there a good reason why you're running straight water? Antifreeze prevents boiling over, prevents the water in the block from freezing and ruining it, prevents internal rust, and it lubricates things like the water pump (water isn't a lubricant). Needless to say, using only water is bad.
Old 11-30-2011, 01:05 AM
iLL95's Avatar
I Like to Party
Super Member
There is usually a ratio of water to coolant (60/40?), how much dripping is there? minimal or alot? Usually it is condensation built up inside the pipes
Old 11-30-2011, 02:34 AM
It's a newer rebuilt engine and has ran great, temp stays at 180, but recently I have had to refill the radiator every week or so, but have not been able to trace a leak, which is why I used water a few times, but thanks Camaro 69 for the prompt to use radiator fluid. (I replaced water pump just in case last week.) I never see it leaking from front of car, not sure where coolant is going...
Old 11-30-2011, 01:34 PM
Hmmmmm....let's see if we can put two and three together:
1) You're refilling the radiator weekly.
2) You see no external leaks.
3) You're questioning about water dripping out of the exhaust.
4) Your cooling system is filled with water.
If water isn't leaking on the outside, you'd have to be losing it on the inside. Head or intake gasket would be the suspect.
Old 11-30-2011, 01:38 PM
iLL95's Avatar
I Like to Party
Super Member
^Ouch. Meaning you need to open 'er up and check your gaskets. Although I thought if it was leaking internally there would be smoke/vapor due to the heat that the engine gives off?
Icecobra
67-69 V8 Tech
11-07-2014 05:44 AM
dlaidoutranger
06-03-2012 09:17 PM
Texas70z28
06-06-2011 08:52 AM
BLK_CZ28
10-13-2009 11:39 PM
ronbo1044
03-31-2006 09:11 AM
Quick Reply: Water dripping from exhaust pipes
