Carb Trouble! Need help!
Old Dec 4, 2011 | 10:43 AM
kbar's Avatar
Default Carb Trouble! Need help!
Ok So I have Holley 1850s on top of a preformer rpm intake manifold. I can bring my car down to proper idle rpm with out it dying. The vacuum is fluctuating from 17-10. I can tell there is a leak around the intake, the vacuum advance works, the brake booster is holding vacuum as well. Idk what to do?? Need help!
Old Dec 4, 2011 | 11:03 AM
have you lifted the carb up to make sure the gasket is sealing right.
Old Dec 4, 2011 | 11:07 AM
iLL95's Avatar
I Like to Party
Super Member
If there is a leak around the intake (Upper i'm assuming) Like crabs said, I would check the gasket, vacuum shouldn't matter at this point if all the valves a hoses are sealed correctly
Old Dec 4, 2011 | 11:25 AM
You need to replace your leaking carburetor base gasket (between the carb and intake). Did you use an adapter plate of any kind?
Old Dec 4, 2011 | 11:54 AM
kbar's Avatar
No adapter plate, it didnt have one on it before I pulled the carb off.
And I'm sorry I ment to put I think there is a leak around the intake. It's my last guest on what's going on. And I think the carb was sealed fine. Has a brand new gasket on it.
jeanann73
Feb 2, 2013 09:05 PM
albo1989
82-92 V8 Tech
Jul 1, 2010 07:40 PM
Jr. Mechanic
Jul 4, 2009 11:35 AM
c4maro
Feb 1, 2009 06:12 PM
Camaro_Boi69
Jun 6, 2008 11:13 PM
