Small Block Displacement
Old 05-27-2006, 03:25 PM
Default Small Block Displacement
Chevy Generation I ,original small block
265 in³ (4.3 L) 3.75€œ (95 mm) X 3.00€ (76 mm)
1954-1956
162 hp to 240 hp
283 in³ (4.6 L) 3.75€œ (95 mm) X 3.87€ (98 mm)
1957-1967
185 hp to 315 hp
302 in³ (4.9 L) 4.00€ (102 mm) X 3.00€ (76 mm)
1967-1969
290 hp
307 in³ (5.0 L) 3.875€ (98.4 mm) X 3.25€
1968-1973
115 hp to 200 hp
327 in³ (5.4 L) 4.00€ (102 mm) X 3.25€
1962-1968
250 hp to 360 hp
400 in³ 4.25€ bore X 3.75€
1970-1979
240 hp
262 in³ (4.3 L) 3.67€ (93 mm) X 3.10€ (78.7 mm)
1975-1976
110 hp
267 in³ (4.4 L) 3.50€ X 3.48€ (88.4 mm)
1979-1982
305 in³ (5.0 L) 3.74€ (95 mm) X 3.48€ (88.4 mm)
1976-2003
130 hp to 250 hp
350 in³ (5.7 L) 4.00€ (102 mm) X 3.48€ (88.4 mm)
1969-2000
125 hp to 370 hp
Chevy Generation X
LT5 DOHC 349 in³ (5.7 L) 3.9€ (99 mm) X 3.66€ (93 mm) ZR1 Vette
1990-1995
375 hp to 405 hp (LT5 DOHC or quad cam)
Chevy Generation II, LT series
LT1 (4.3 L to 5.7L)
1992-1997
200 hp to 305 hp
LT4 (5.7 L) 4.00€ (102 mm) X 3.48€ (88.4 mm)
1996-1997
330 hp
Chevy Generation III, LS series
LS1 346 in³ (5.7 L) 3.90" X 3.62"
1997-2005
305 hp to 350 hp
LS2 346 in³ (5.7 L) 3.90" X 3.62"
2004-2006
400 hp
LS4 325 in³ (5.3 L) 3.78" X 3.62" (front drive application)
2006-??
303 hp
LS7 427.6 in³ (7.0 L) 4.125" (104.8-mm) X 4" (101.6-mm)
2005-??
505 hp
LS9 6.2L
2010
600 hp (supercharged)
Vortec 4800, 5300, 6000
LS series truck engines
Old 05-28-2006, 01:32 PM
94Z28SHAKER's Avatar
Default RE: Small Block Displacement
Isnt the LT5 a quad cam for the Zr1 vette? I believe aston martin helped GM design them with 4 camshafts and Gm actually had mercury marine put them in the car.
and i think the LS4 which is in the V8 impala produces 303 hp
Old 05-28-2006, 02:09 PM
That is exactly what it is, GM used to call it a Twin Double Overhead Cam, Two cams on each head, for 4 cams total. Gets confusing when you get too fancy with names. Correct about the LS4, looks like a typo & will fix.
Old 07-02-2009, 06:12 PM
cbr600rx7's Avatar
The LS2 is 364ci by 4.00 x 3.62
Also the LS3 is 430hp at 372ci by 4.06 x 3.62 2008+
Old 08-17-2009, 06:43 PM
NYH1's Avatar
The 283 is 3.875" X 3.00" (98.4 mm 76.2 mm). The 400 is 4.125" X 3.75" (104.8 mm 95.2 mm).
snopro_16
67-69 V8 Tech
14
08-23-2022 04:08 PM
z28pete
05-02-2012 01:30 PM
gadmhahn
10-09-2009 09:20 PM
acarius
04-07-2009 05:53 PM
Carinhas
67-69 V8 Tech
13
08-23-2007 05:02 PM
Quick Reply: Small Block Displacement
