the best stock cylinder heads
Old 03-06-2007, 10:06 AM
a356708's Avatar
Default the best stock cylinder heads
i have a 1967 327 i am putting in my 1968 camaro.wich heads would be the best for my block? the casting on heads are#462624 or #3998993?
Old 03-07-2007, 08:36 PM
coprunr's Avatar
Default RE: the best stock cylinder heads
the best stock cast iron heads for your 327 are the L31 Vortec heads. they outflow every stock SBC head ever made including the old Bowtie heads and outflow ALOT of aftermarket heads. the only draw back to them is you have to use a Vortec specific intake and intake gaskets. i have seen the Vortec heads make 350+ hp right out of the box. best choice in cast stock heads there is.
Nightsteed02
02-22-2011 12:13 PM
1976camaro
70-81 V8 Tech
10
12-14-2010 05:28 PM
Roy
03-15-2008 08:19 PM
z28west
01-09-2007 07:05 PM
cubancamaro
01-06-2007 09:42 PM
Quick Reply: the best stock cylinder heads
