LT1/LT4 Tech 1993-1997
Cylinder heads. Help Please.
Old Jan 1, 2007 | 03:41 PM
z28west's Avatar
Default Cylinder heads. Help Please.
Will it hurt your lt1 engine to put the heads on the opposite sides?Im embarrased to say so, but im a very newb to engine building and did this. Honestly I shouldnt have been doing it myself, but I didnt have the money to get a professional rebuild my engine, and some one I knew who does know mechanics said hed help. Then he quit halfway through, and left me to finish what he began. Long story.So anyway, I put the heads on backwards. The head cooler line I relocated, with some trouble but it works. I took off the smog pump. Everything mates up fine. However, the engine backfires, and wont start. Like I said previously it has fuel, spark, and a new distributor, plugs, wires, filters, supposedly proper timing,and the computer is good. Could the heads be the problem? I really need some input. Thanks
Old Jan 9, 2007 | 04:47 PM
uncle bill's Avatar
Default RE: Cylinder heads. Help Please.
The heads will interchange sides with no problem.
Old Jan 9, 2007 | 07:05 PM
If you have a 95 & erlier LT1 it is possible tojam the distributor in 180 deg out, you may want to check that out. Also make sure the ignition wires are going to the right place.
oilfieldtrash7
82-92 V8 Tech
Apr 3, 2012 08:51 AM
Nightsteed02
Feb 22, 2011 12:13 PM
1976camaro
70-81 V8 Tech
10
Dec 14, 2010 05:28 PM
79 Berlinetta
Apr 10, 2010 01:11 AM
blowncamaro
Nov 16, 2009 11:18 AM
