2001 t-top sail panel coming loose on driver side
Old 11-19-2014, 11:17 PM
J-Factor's Avatar
Default 2001 t-top sail panel coming loose on driver side
Recently I noticed some wind noise on the driver side when I'm going down the road. I thought it was no big deal until it got below freezing the last week and a half and the back edge of the driver side window suddenly became an ac vent. Turns out the sail panel is coming up a bit on the driver side and has become a scoop forcing the cold air in going down the road. Question is how do I get it back down like it's supposed to be. Corvette guy I work with suggested using a syringe to get some gm adhesive in there and using aluminum tape to hold it down while it cures. It makes sense but I just want to be sure before I go messing with it.
Old 11-20-2014, 04:54 AM
pictures. sail I'm thinking about is on the inside in front of the window.
Old 11-21-2014, 06:29 AM
J-Factor's Avatar
I'll get pics if I can this weekend craby. It's the panel that runs from the side, over the top and down the other side. Top runs between my ttops and hatch.
Old 11-21-2014, 08:22 AM
J-Factor's Avatar
This isn't my car but the cf piece in the pic is the sail panel
Old 11-21-2014, 10:22 AM
Everett#2390's Avatar
The external panel, not the interior panel?
Body shop should have the right adhesive.
There is an FYI link on this forum about replacement roof panels in a recall.
Old 02-12-2015, 07:26 PM
J-Factor's Avatar
Actually it's a service bulletin. The only way you could get one dealer replaced was under warranty. The panels are also discontinued and the only new ones I've found are 700 for fiberglass and 800 for cf from 6LE. Way overpriced for a chunk of fiberglass. I'll just have to figure out how to cover up the bubbles once I get it fixed. Trying to track down a polyurethane cover like this guy on youtube had.
Old 02-18-2015, 06:16 PM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
Go to the junk yard and pull one off a lt1 body style car, they had the better sail panels IIRC
Old 02-20-2015, 12:37 PM
J-Factor's Avatar
Socom, I might attempt this over the summer when it starts hitting over 100 outside. The Texas sun is sure to make the adhesive easier to work loose.
Z28Camaro98
12-21-2012 11:18 PM
Roger3
09-03-2012 05:06 PM
Thanatos
02-07-2012 10:56 AM
Adooley
02-27-2011 11:02 AM
CamaroZ99
07-11-2010 04:08 PM
Quick Reply: 2001 t-top sail panel coming loose on driver side
