Headlight conversion (HIDS)
Yes it is possible and it is a sticky.
https://camaroforums.com/forum/audio-visual-electronics-20/4th-gen-hid-install-sealed-beams-too-33474/
Learn the search function.
The balast has something to do with the power because it takes more power to get the bulb going but less to keep it going so i am assuming the ballast has something to do with regulating power. I got mine from hidkit.com it comes with two lights two ballasts two metal mounts and two pieces of dubble back adhesive. I just used the adheasive.
thanks gorn
quick question though.
are these HIDS are something else?
http://eurolamps.com/eurolamps/camaro_headlights.htm
is there a color chart or something where i can see the actual color?
Those are housings for 93-97 sealed beam headlights to convert them to adding just bulbs and/or HIDs. So you need something like that PLUS HIDs & ballasts for 93-97 Camaros...
thanks gorn
