easiest way to do burn outs
Old 06-02-2007, 05:16 PM
408camaro's Avatar
Default easiest way to do burn outs
whats the easiest way to brun out on my 98 3.8 ****ed up somethings before dont want same prob's happening again.
Old 06-02-2007, 05:17 PM
408camaro's Avatar
Default RE: easiest way to do burn outs
burn* my bad
Old 06-02-2007, 06:24 PM
Hate to tell you, but burn outs are not good for the car, and are not good for acceleration either. But if you want to lessen the stress, go with skinny tires and high tire pressure. If you have a manual tranny don't dump the clutch as it will make things break.
Old 06-02-2007, 10:49 PM
libertyforall1776's Avatar
Get the SLP Brake Line Lock for your year car:
http://slponline.com
Old 06-04-2007, 08:13 AM
buddywackos's Avatar
just about the only way to get our v6's to burn out is to dump the clutch. but seeing as how that is hard on the car i usually punch it and turn the wheels hard to the right to get it going instead of dumping the clutch.
Old 06-04-2007, 02:19 PM
tatued32's Avatar
my 3.8 will burn out without a problem,i can take off from a dead stop,hit it about half a pedal and it will lay down some rubber,if i stay in it it will even catch 2nd gear for a decent squel on occaision,i havent modded it a great deal at all other than a flowmaster cat backsystem and a CAI its stock,but has aleays had plenty of power, well until recently,i though my motor was going out because i had lost power and had a clicking noise,turned out to be a bad injector,everything is fine again. but if you want to do burn out try powerbraking it...not a good idea but it should smoke the tires
Old 06-04-2007, 03:05 PM
badinfluenceRS's Avatar
LS1 Mod
My 96 3.8, all stock, stock tires would lite them up really good
Old 06-04-2007, 04:25 PM
ninetysixyenko's Avatar
mine lites them up really good even with 9.5inch tires in the back, i just let the clutch out slow so it's rolling without stalling then step on the gas and it'll spin for a good 5 seconds at 4grand RPMs, and then i usually jus push clutch back in and let off gas, dont bother switching into 2nd. doesnt even squeal or smoke =) just hear nice tunneling sound and roar of engine
xXChipXx
12-28-2010 10:42 AM
Bwalker
70-81 V8 Tech
09-17-2009 09:24 PM
2002SLP
06-30-2008 12:20 AM
SomeCallMeFonzi
05-19-2007 04:28 PM
FunkyColdMedina
01-26-2007 07:20 PM
Quick Reply: easiest way to do burn outs
