Help with bleeding clutch! Stuck pedal!
Old 09-02-2015, 01:59 PM
djsquare1's Avatar
Default SOLVED - Help with bleeding clutch! Stuck pedal!
So I'm at work and decided to drill a hole in my transmission tunnel on my car to access the slave bleeder. I wanted to bleed as I replaced the clutch last year but have had a soft pedal ever since and sometimes it sticks to the floor after hard shifting. I bled it with a mity vac set up the first time so this time I decided to do it from the slave bleeder screw.
All went well and I managed to get some air out. The pedal was sticking to the floor during bleeding so I kept having to pull it back out.
Now the pedal is stuck to the floor, I can pull it back out but it has no resistance when I push it to the floor anymore so I can't continue to bleed and now I'm stuck at work trying to figure out whats going on.
Yes the reservoir is full. Yes I was pushing down the pedal, cracking the bleeder, closing it and releasing the pedal. On my last crack of the bleeder a bunch of fluid squirted out and can't get any pressure on the clutch pedal to continue.
Hopefully someone can help me! :s
UPDATE:
I'M AN IDIOT! I was watching the reservoir on the master cylinder meanwhile the clutch reservoir went bone dry. This would explain the sticking clutch pedal HAH!
I re-bled after figuring out that i am an idiot and all is perfect now. LOL!
Old 09-02-2015, 03:30 PM
I think maybe I'll let the thread hang around for a little bit, just in case somebody else has the same brain fart.
Old 09-02-2015, 03:53 PM
djsquare1's Avatar
lol good call!
Old 09-02-2015, 05:36 PM
maybe we should sticky it so we can have fun with it for years. lol. we is a self help site.
jasunf
05-03-2010 10:46 AM
ToledoG90
11-18-2008 12:36 PM
slpcamaro
02-19-2008 06:34 PM
cdcamaro
09-26-2007 11:21 AM
waro
07-02-2006 11:53 PM
Quick Reply: Help with bleeding clutch! Stuck pedal!
