Sway bar link kit questions
Old 12-14-2010, 09:11 PM
1augapfel's Avatar
Default Sway bar link kit questions
My 94 V6 has all the goodies including the salad shooter wheels with F41 suspension. As far as I can tell the important suspension items listed on my car's glove box sticker are that and FE9.
If you look at the Camaro parts pdf you'll see that the front suspension section lists two different sway bar link kits. One has no qualifier while the other is for cars with FE2, FE4, and FE7.
Well I've already told you what is listed on my car's sticker (FE9 & F41) so which kit do I use?
It gets better. Just a few lines after listing the two possibilities for sway bar link kits, the parts pdf lists the relevant option codes as:
FE2 - firm ride and handling
FE4 - special ride and handling
FE7 - front and rear suspension, heavy duty
F41 - firm ride/handling, front and rear
What about FE9 which is on my car? Is FE9 even heavier duty than FE7?
When I did my engine and front suspension work I installed new Moog sway bar link kits up front. For reasons I can;t remember I bought kit K5252 which Rockauto describes as the ones for front suspension "standard design" and rear suspension "standard duty, standard design." They also offer Moog K6217 for rear suspension, "heavy duty" and a K6630 for front suspension "problem solver heavy duty design"/rear suspension standard duty "problem solver heavy duty design."
Confused?
My brain is kind of fried at the moment. Do you think that F41 is considered heavy duty suspension? What about
FE9? Do you think any of the the kits will work in a front or rear application, the only difference being how strong the kit components are (and how long the links will last.)
Old 12-14-2010, 09:16 PM
BasicConcepts's Avatar
Technical User
id say just get some from autozone
Ben Myers
10-23-2012 09:28 PM
thefley
06-13-2012 02:40 PM
TomBigBlock
03-30-2010 07:36 PM
bazkook
05-28-2007 11:25 PM
microkid
11-27-2006 12:47 AM
Quick Reply: Sway bar link kit questions
