89 into 88 engine swap questions
Old 09-13-2006, 04:54 AM
Z28Nurse's Avatar
Default 89 into 88 engine swap questions
WOW I've got lot's of questions for all of you able minded CAMARO Guru's out there!
I've got an 1988 IROC Z28 convertible with a 305 with TBI. I wanna put a 350 in it. I have a 1989 IROC Z28 donor car available with a 350 TPI in it lined up. Should I buy the donor car route or buy the motor out of the car? What items should I be sure to transfer from the 350 engine? The 89 to 88 year has got me nervous are there any other conversion things I should take care of? Do you anticipate any any automatic transmisission issues trading up from a 305 to the 350? Do you know of any literature or resources that can assist me and my husband with this engine swap project?
[/size] Thank you!
Old 09-13-2006, 09:39 AM
blackz87's Avatar
Default RE: 89 into 88 engine swap questions
As long as you have a donor car with the 350 TPI complete you should not have any major problems.
One of the big problems with a TPI into a TBI car is the wiring harness, sensors and the ECM, and you will have that covered. Most external engine parts are common between a 305 & 350. Also the drive train is no problem.
wmjlowe
07-24-2014 10:26 AM
BLK79
70-81 V8 Tech
05-04-2014 12:33 PM
kevilay
82-92 V8 Tech
10
01-09-2011 06:35 AM
Mitshiko
82-92 V8 Tech
07-09-2009 02:10 PM
SomeCallMeFonzi
01-11-2007 10:24 PM
Quick Reply: 89 into 88 engine swap questions
